Yes sir, overcharging will do it:ermm:
If it has gone dry so quickly, I would suggest that you run the risk of having a battery explosion if the fault continues.
It is imperitive that you determine what the charging voltage is when you instal a fresh battery.
Nominally 13.8V - 14V.
Any more and you may re-enact the "China Syndrome":nervous:
It is a good idea to have a reputable supplier instal the new battery.
They will usually do a check of your system then for voltage and regulation of charge.
Only a couple of seconds work but well worth the effort.
https://www.classiczcars.com/topic/24418-dry-batteries/#findComment-210485
thats what i thought. what would cause it? i havent been able to determine if my alternator is interally or externally regulated. im thinking it is externally & the regulator isnt working. i was thinking it was an internally regulated alternator but they left the old regulator there. theres also a very low rated inline fuse that looks spliced into a wire off the external.
thanks for the help
https://www.classiczcars.com/topic/24418-dry-batteries/#findComment-210507
You haven't said what year your car is but the earlier cars, 240z, 260z, early 280z would be externally regulated unless they've been converted. And, I might be wrong but I believe that only the 1978 280z was internally regulated from the factory.
https://www.classiczcars.com/topic/24418-dry-batteries/#findComment-210508
Oh sorry. It's a 73 with a L28 w/ electronic ignition swap. I haven't seen a comparison of internally & extrernally regulated alternators but, something about the back of the 1 on there has me thinkin it's internally regulated. Theres so much half-assed wiring that I'm not sure what's goin on tho
https://www.classiczcars.com/topic/24418-dry-batteries/#findComment-210519
