I am moving (finally !!) on my front end and I would like to freshen everything rubber if possible. Does anyone know where I can get new o-rings that sit between the steering knuckle arm and the bottom of the strut tube casting?
Or any official names it may have ?
Look at diagram #1 on the top of the page
http://www.blackdragonauto.com/icatalog/z/0097.asp
Thanks as always - this forum is a great resource and I want to thank everyone that posts and especially thank you to those that post pictures.
yeah I remember this part, this should come with the ball joint I guess..
but a sealan should be able to take care coz there is no differential pressure which might force the dirt to come in..
but if you take the old one and go arround spare parts shop or any industrial shops you can find similar one, coz it is just a simple O-ring, not a big deal to be baught from a specialized dealer of S30s
good luck pal.
Thanks guys - I bought the MOOG ball joints from Rock Auto and they did not include the o-rings. I found a spot on the web that sells them in all sizes and materials. I will order something close and strech it - or I might just say F%#$ it and use the RTV -thanks for the tip.
  • 1 month later...
  • 1 month later...
