Site going down soon for upgrades ×
Unless you're using a cleaner wax then waxing just adds a layer on top. I'd start out with something mild and work your way up if it doesn't work. There are various polishing and rubbing compounds.
I've used the "fine cut cleaner" from Meguiars but they have plenty of products that can help you. Another option is a clay bar or wet sanding. You could start with 2000 grit wet paper without worrying about doing much damage.
http://www.meguiars.com/estore/product_list.cfm?&sectionname=Professional%20(Mirror%20Glaze%20Brand)%3EAuto%20Paint%20Care%3EPaint%20Cleaners/Compounds&sectionID=31301
https://www.classiczcars.com/topic/24560-gasoline-stain/#findComment-211919
