Sounds to me that your choke cable is a bit too tight. I'd try adjusting at the carbs, if you have enough length, to let more cable into the sheath. If that doesn't work, maybe reposition your choke cable differently for a shorter shot to the carbs.
https://www.classiczcars.com/topic/24561-choke/#findComment-212074
  • 1 month later...
