I was under the impression it did because the air was thinner and the carbs needed to be run a little richer to compensate. Ztherapy asks if you live above 6K ft elevation when they rebuild your carbs...not sure exactly why but I assume it's so they can change something in the configuration of what they end up sending you.
Another option may be to replace the fuel filter. My tank probably needs a good cleaning and when the fuel filter gets plugged up, less fuel makes it to the carbs.
You have the mixture for altitude backwards. Hi altitude leaner. 58 needle instead of a 54. gogriz RX-7 fuel pump from a '79 or '80 at the u-pull-it $15.00 I like that price much better. They pump 4.5 to 5 PSI and lots of volume. I run one with no mechanical and have for 6+ yrs with no problem with carbs or lean issue from lack of fuel , or too much pressure. Put one on a stroker engine with triples and it fed it great also. After 5+ years of use I did have one fail. But had a spare and made the change. Gary They are almost silent also. Gary
  • 3 weeks later...
:stupid::stupid::stupid:
When my car first stalled on the road in the heat, my first thought was ,"fuel filter or Fuel pump" so there on the side of the road I checked the filter by disconnecting the fuel line at the pump and blowing backwards through the filter towards the tank. It felt clear and when I cranked it a few minutes later I could see fuel entering the filter and it started so I figured both were OK and the heat was the problem. A few days ago it was nice and cool so I(still thinking vapor lock) took it for a spin. It began to act fuel starved. So this time I took it home,removed the fuel filter and tried to blow through the inlet side of the filter and almost ruptured my ear drums it was so clogged up. Ten minutes and $3.00 later it runs perfect heat or cool.:rolleyes:
But I am grateful for all the instant help and suggestions.
Best
H Houghton
