IVAN:
I installed a small (about eight inch diameter) fan on the radiator and hooked it to the stock electrical system. I didn't remove the stock fan, so I had to install the fan as a pusher rather than a puller. The fan has a thermostat unit that is inserted into the radiator fins. It proved to be a cheap and effective cure to my overheating problems.
  • Who's Online   0 Members, 0 Anonymous, 1,142 Guests (See full list)
