I have a 73 w/ L28 & tripple webers & have always had a lil problem with the fuel supply being unstable. The pump just went out, so I replaced it with a carter 4070. Come to find out the pump that was on there (I thought it was original) is a mitsubishi pump. Did mistubishi even have a performance carb'd car in the us? Anyway I put the carter on yesterday & the car had more power & didn't bog or stumble at all. This morning on the way to work it kept flooding to the point it would stall. I have a switch for the pump & had to turn the pump off for a min as soon as it started to bog (all the way to work). I'm sure it needs to be tuned now but, the second it stalls, fuel pours out through the air filter. Mainly from the 3rd carb. I've been meaning to change the banjo on that carb to make the system back to having a return line. Any help?
https://www.classiczcars.com/topic/24943-carter-4070-issue/
A Carter 4070 can push good volume of fuel at approx. 4psi, and this might be too much for your fuel bowl floats and gross jets to handle, you get fuel flooding out the carbs and this could be a fire hazard near the hot exhaust manifold. If you wish to use this or another after market electric fuel pump you may need to install a fuel pressure regulator after the pump and before your fuel line "T"s to both carbs. Holley and others make pressure regulators you can install inline and adjust to bring the pressure from the pump down to around to 2.5 to 3psi. This can be done by trial and error, keep cutting the fuel back until you stop flooding your carbs, or better yet purchase a fuel pressure gauge and install it off of the "T" of the pressure regulator so you can see the fuel pressure.
Modified motors with larger cams, thirsty carbs, fuel line OD and running at high rpms may fuel starve a motor acting like it's cutting out, or Rev limiter is coming on... been there with that problem. My correction was with a 7 psi Carter pump and pressure regulator at 5- 5.25 psi. So you can see I was having just the opposite problem.
Good Luck.
Hmm, well I guess you proved them wrong. You may need to look at the Webers to see which one is not holding back what that Carter is putting out. I don't think Carter's statement of no regulator required will be worth much once the car burns to the ground after going up in flames from fuel all over the header... that would not be good.
ok I got a fuel pressure gauge on. it's this lil spectre pos & while i never thought it was precise, it always seemed about where I thought it would be on my spitfire. anyway if it IS, that pump is puttin out about 8psi when its supposed to be about 4. defective pump?
Same thoughts here. They (TEP) say the Carter 4070 cause it is supposed to be around 4 psi. "No regulator required"
But it sounds like it's defective so if it's always gonna put out 8 pounds, go with a regulator just to be safe. I just bought a triple set of 40 DCOE's for $800 so I think I'l go with the Carter and a regulator (for the hell of it)
Dave.
  • Who's Online   1 Member, 0 Anonymous, 1,291 Guests (See full list)
