maybe something like these:
http://www.autosportcatalog.com/index.cfm?fa=p&pid=1410&cid=45
with 240Z for the monogram...
for some reason these look a bit retro to me (which is good):
http://www.autosportcatalog.com/index.cfm?fa=p&pid=1304&cid=45
bummer, I just noticed this line "cannot designate a vehicle manufacturer's name, make or model. " We'll back to the drawingboard.
I've been thinking about coco mats for mine. I made the mistake of buying the 280Z logo mats from MSA--very cheap. The foam backing doesn't grip the carpet at all so the left mat occasionally slides under the gas pedal causing it to stick open. They also develop a permanent bend to match the tranny tunnel curve, which isn't bad until they slide away from the tunnel, leaving a gap.
Try looking at RoadWorksAuto.com. They have their "Designer Mats" in 32oz nylon, nibbed backing and serged edging listed under the plush floor mats that are a good match to the OEM carpeting. I bought a set for my 280z. They were very pricey, over $100 dollars. But very good/heavy duty quality. I shouldn't have to buy another set again.
  • 1 month later...
I bought a large (industrial) floor mat ( 4x6, IIRC) from the DIY place. It is rubber with carpet on top. I cut it up to put under the seats, in the back, and for floor mats. I used carboard/posterboard to make a pattern, and I made metal tabs of aluminum that were rivetted to the forward edge, and the kickpanel screws go through a hole to keep the floor mats in place.
thxZ
