Roller pilot bearings cut down wear and tear that stock bearings put on your input shaft. I'd say, if you're going to go in there anyway, why not? I have them in all three of my street driven Datsuns. I've been told that they require more maintainence, but I've not had any problems yet.
https://www.classiczcars.com/topic/25040-pilot-bearing/#findComment-216759
OH GAWD I'd like to shoot the previous owner who put in a roller pilot bearing before I owned the car. Once the bearing had become worn enough, it just fell apart while removing it but the outer race of the bearing was determined not to come out. Every trick we could try, fire, ice, pry, grease & pressure trick, and finally after finding a strong enough metal demel bit to cut this hardened metal ring.... I won the battle! Sumbitch I'd rather replace 5 brass bearings over wrestling one broken roller bearing any day. Sorry, I still have a bad taste from that episode!
:P
They might be a better idea in theory, until you have to remove one that has gone bad.
Good luck.
https://www.classiczcars.com/topic/25040-pilot-bearing/#findComment-216769
Come to think of it, I only have them in the two that I don't drive much. My daily driver still has the bronze bushing in it. The Z and the truck have them and I don't think I've put more that about 1500-2000 miles on either of them since the install. How long do I have?
https://www.classiczcars.com/topic/25040-pilot-bearing/#findComment-216787
From the thread I read..You pretty much pulled the pin on that grenade. Coffey was changing his every 15 to 20 hrs when he changed the clutch.
For the little track time I get and as much as I drive my Z I'll go with a oillite bearing.
http://forums.hybridz.org/showthread.php?t=111696&highlight=roller+pilot+bearing
Eric
https://www.classiczcars.com/topic/25040-pilot-bearing/#findComment-216824
Roller pilot bearings are really only needed when regularly shifting past 7,500 rpm. I tried a few on the Rusty Old Datsun and hated 'em. Went back to the OEM bronze bearing and didn't notice any difference. This is how the bearings typically looked after I removed them:
https://www.classiczcars.com/topic/25040-pilot-bearing/#findComment-217309
  • Who's Online   1 Member, 0 Anonymous, 1,599 Guests (See full list)
