Everyone's right about the standard NGK plugs in a Z. Before you go regaping those iridium plugs though, DON'T!!!!! If you try to gap iridium plugs you will crack the ceramic. That tiny little iridium tip isn't strong enough to take the force of a plug gapper pressing the ground electrode out, it will give and crack the ceramic around it. Most of the iridiums usually have a warning on the box telling you not to regap the plugs.
https://www.classiczcars.com/topic/25199-spark-plug-gap/#findComment-218363
The carbs will run lean during warm up unless the choke is set. I would swap to the standard NGK plugs now and see if your lean backfire doesnt go away. Your money would be better spent on switching to a newer 280Z electronic distributor with E12-80 module and a hotter coil. The swap is quite easy and it will provide a better overall ignition system.
https://www.classiczcars.com/topic/25199-spark-plug-gap/#findComment-218371
But if you do that swap you'll want to go to the NGK B6ES-11 and gap them at .039-.043.
https://www.classiczcars.com/topic/25199-spark-plug-gap/#findComment-218376
