Holley Carb - Manual or Automatic Choke ???
I just tuned my 1973 240z which has a 390 cfm Holley 4 Barrell carb. It runs super once wamed up,. It was an Arizona car and actually had the choke butterfly clamped wide open all the time. For starting in Arizona - I'm sure this was fine, but since I live in the upper Mid-West, I need the choke for cool and cold days to effectively start it.
Question :
1) Should I use a Manual Choke since the car is equipped with the lever on the console and choke light?
1a) If yes - has anyone wired up the choke light and can give me tips on where to connect the choke switch to the wiring harness ?
2) Should I use the Holley automatic choke and have it calibrated and adjusted for my weather in the upper Mid-West?
I was leaning toward the manual choke option because it's easily adjustable but unless I can connect the Choke light up so I don;t accidentally leave it on all the time - I can be swayed to having the Holley carb's automatic choke be activated and adjusted.
I welcome comments and thoughts. Many thanks.
Thanks for such a quick response! My Holley automatic choke is not electrically connected, so I presume before I do anything, I can hook it up and try it. I have not looked closely enough to see where the wire connects to the Holley carb.
I presume the wire input to the electronic choke on the carb comes from a hot wire off the ignition circuit.
Many thanks.
You presume correctly.
How are those switches working out for ya?
You might even want to run a relay on that choke. Just for safety sake.
1) power wire from the battery to terminal 87
2) wire from terminal 30 to the choke
3) terminal 85 to a ground (most likely the same metal where you mount the relay, on the firewall?)
4) terminal 86 to an ignition wire or to the ignition it self.
Any 4 or 5 prong relay rated at 20 or more amps
Dave.
Thanks Dave for the thought. I don't follow your number schemes , like temrinal 30 or terminal 87 ? Explain in simple terms for me would help.
Once I re-assembled the switches and the interior I spent Saturday doing some tuning of my Holley carb. I haven't taken it out yet for a cruise - but the switches Turn & Combo work superbly!
Many thanks.
  • Who's Online   2 Members, 0 Anonymous, 1,292 Guests (See full list)
