popdaddy Posted August 28, 2007 Share #1 Posted August 28, 2007 I have a 72 240,new battery,alternator,voltage regulator.Car is overcharging, also when brake lights are on or I turn on blinkers,needle pegs the gauge.Any ideas? Link to comment https://www.classiczcars.com/topic/25348-over-charging/ Share on other sites More sharing options...
a7dz Posted August 28, 2007 Share #2 Posted August 28, 2007 Did you polarize the voltage regulator after you changed it? Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-219959 Share on other sites More sharing options...
SteveJ Posted August 28, 2007 Share #3 Posted August 28, 2007 First, get a voltmeter and take measurements. Let us know what the results are.Second, are you sure you got an alternator that is not internally regulated?Third, what were the circumstances that necessitated changing out the alternator, regulator and battery? Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-219960 Share on other sites More sharing options...
e_racer1999 Posted August 28, 2007 Share #4 Posted August 28, 2007 would the alternator even work if it was IR and you had a VR plugged into it? Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-219962 Share on other sites More sharing options...
SteveJ Posted August 28, 2007 Share #5 Posted August 28, 2007 Yes. In my case, the voltage peaked somewhere around 18 volts. That's what happens when you do parts replacements/upgrades without the proper research. Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-219963 Share on other sites More sharing options...
popdaddy Posted August 28, 2007 Author Share #6 Posted August 28, 2007 Jim,what do you mean by polarizing? Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-219964 Share on other sites More sharing options...
popdaddy Posted August 28, 2007 Author Share #7 Posted August 28, 2007 Also if it were internally regulated, would the t connector be available on the back of new alt.? Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-219965 Share on other sites More sharing options...
SteveJ Posted August 28, 2007 Share #8 Posted August 28, 2007 IIRC, it was all plug and play to drop in the interally regulated alternator (well, except for the conflict between the internal and external regulator and the fact that you need to install diodes to prevent feedback that will cause run-on, but I digress). I'll try to remember to look at my car tonight to verify. What is the rated output on your new alternator? Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-219998 Share on other sites More sharing options...
e_racer1999 Posted August 28, 2007 Share #9 Posted August 28, 2007 ^what's interesting is that i didn't have to install a diode :/ Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-220012 Share on other sites More sharing options...
Biz280Z Posted August 28, 2007 Share #10 Posted August 28, 2007 I had this problem with my original 72. It was the lead at the voltage regulator that feeds back to the battery to tell it what the charge sate is. It was broken at the connector under the regulator. If it;s not connected it will be telling the regulator that the battery is dead to give it max charge. If I remember right it was a white wire. Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-220029 Share on other sites More sharing options...
e_racer1999 Posted August 28, 2007 Share #11 Posted August 28, 2007 ^good call. that's probably what it is... something in the "sense" circuit is probably messed up Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-220030 Share on other sites More sharing options...
SteveJ Posted August 29, 2007 Share #12 Posted August 29, 2007 Also if it were internally regulated, would the t connector be available on the back of new alt.?I looked at my car. Yes, it's pretty much plug and play. Link to comment https://www.classiczcars.com/topic/25348-over-charging/#findComment-220049 Share on other sites More sharing options...
