Carbs set full lean, still running rich
remove the top of the carbs (big round bell shaped peice) and check the seating of the needle. The best starting point is to hold the sleeve (with the needle attached) upside down, with the needle pointing upwards, the needle goes from pointy tip down to a thicker shape, it will then have a flat lip that should be level with the flat surface of the sleeve.
If not, then loosen the screw on the side of the sleeve and use a flat metal plate or ruler to seat it flush and then retighten. Do this to both needles on both carbs and carefully re-install them back into the carbs, while paying close attension to how easy the sleeve rises and falls as you tighten down the tops. then replace the oil that came out when you turned the sleeves upside down.
Pics should help
Picture 1 shows how to adjust it,
picture 2 is a decent picture of the same,
picture 3 is showing how to raise and let fall the needle while tightening the top dome down.
Dave.
The needles are fine.
The chokes are disconnected...it came that way. Should the lever be pulled all the way back or forward? (this is my first car with a manual choke...or even a choke for that matter)
How are the floats properly adjusted? I just read something about putting an 1/8th drill bit under the float and bending the metal "pivot" so it just sits on top.
If the choke cables are disconnected it doesnt matter where the lever is. When the cables are connected the console lever will be forward for the "choke off" position and the nozzles will be tight against the bottom of the carbs. I believe the nozzles are spring loaded and should be held in the up position with the cables off, but Im not absolutely sure of that. You might want to check to see if you can move the nozzles up and down by hand.
I've not had to adjust my carb floats so I cant help you there. Others here on the board can probably answer that question.
Good Luck
A spring in the choke linkage on the side of the carb holds the nozzle up. The cable can be disconnected but the final link to the nozzle has to be attached. If it isn't the nozzle can drop far enough to cause an extremely rich mixture.
3 possible causes in the float bowls --
1. Sticking (open) or defective needle valves.
2. Defective floats. They're rigid urethane foam with a very thin skin. If defective or damaged by rough handling liquid gas can fill some of the cells, making the float lose bouyancy.
3. Levels set much too high. With the bendable metal arm on the float just touching the needle (but not compressing the spring in it) the measurement from the other end of that arm (on top of the float) to the underside of the bowl cover should be 13.5-14.5mm. That's 1 mm higher than the spec in the 70-71 FSM, per a tech service bulletin issued in early '73.
I dont understand that.^ I am having the same exact problem with my su's too. and my choke cables are gone too. My car will idle, but when I get on it, it blows black smoke like there is no tomorrow.
Im getting like 12 mpg too.
I will try to explain how to adjust the carbs as best as possible without visuals.
Take the top of the float bowl off. If it's a 4 screw SU this is easy since you don't need to take the carbs off. If its a 3 screw SU, it might be easier to take the carbs off the mainfold.
1) Unscrew the top of the float off. And of coarse unhook hoses(unhook the hose from the fuel rail side because you will need it attached to the float top).
2) Hold the float top with the float attached vertically straight up and down so that the hinged part of the float is at the top. Using the attached fuel line hose, blow into it while at the same time starting to tilt the float towards your right (holding float in left hand) When it is staiaght up and down you should not be able to blow air throught it. But as you keep tilting it there will come a time when air will flow. Once this happens, back up a little bit (less lean) and blow air until you get back to the same spot. This is just a double check to make sure you know exactly where the air started flowing.
3) Once you have got the exact spot use a 1/2" drill bit to measure the space. The space should be a hair over 1/2". Adjust accordingly by bending the plate that attaches to the float.
This is not an exact sicence but it will get you close enough. It did the trick on my Z and now it runs great.
  • Who's Online   1 Member, 0 Anonymous, 1,291 Guests (See full list)
