I've used this Duplicolor high performance wheel paint, in graphite, to do a lot of my suspension pieces. It withstands high temperatures, and is resistant to chipping. I intend to use it on my grille, too......
http://www.duplicolor.com/products/wheel.html
I used this paint on my grill, it worked well ... also powder coating will work super well but is a few more dollars ...
Powdercoating is great, ... I'll agree with that as far as it goes BUT;
If it's not done properly you'll wind up with the same problem I had with the Bumper bars on the rear of my caravan. CANCER BUBBLES. I had to remove the bars, scrape, sand and Killrust then used a spray can silver auto paint to finish the job. I'm now VERY wary of powdercoating. Same as everything, the preparation is 90% of a good job done.
By the way, ... my paint job has lasted a lot longer than the powdercoating did.
Rick.
:devious::devious:
