Who Still Makes 215/60/R14 tires?
I'm assuming the side walls are the same height as the 215/60/14's cause I would like putting wider 225/60/14's like you have on the back. You running 7 inch wide rims with those?
I am running them on 14x7 Western Turbines. The sidewalls would actually be a little bit higher than 215/60s. The 225/60 tire is very close to the stock rolling diameter of 195/70. I have the tires on all four corners.
Gary is correct about rubbing on the front valence. I do rub the front valence on sharp turns, the right moreso than the left.
  • 2 months later...
I found other makers of 215/60/14 !
Kumho Tires makes a set (T rated) but not sure I like the look of them though :ermm:
http://www.tiresdelivered.com/193419453.htm
Heres another source for the Touring Plus version (TR rated)
http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Touring+Plus+732&vehicleSearch=false&partnum=16TR4TPL732&fromCompare1=yes&place=2
Also Kelly Tires makes a VERY neat style with Raised White Letters and
they're made by Goodyear actually :)
I believe they are (H rated) from speaking on the phone.
If you go through Les Scwhab Tires you can get a set special order and
delivered in about five days.
Forgive me as I can't find the pictures again online :cry:
Goodyear has an Eagle GTII (S & T rated) here which is also very nice set with
others like the Hankook Opitmo (H rated).
http://www.rims-n-tires.com/rt_tires.jsp?req=find&startfrom=1&sectionwidth=215&aspectratio=60&biddiameter=14&brand=
eagle_gt_ii.jpgGoodyear optimo_h418.jpgHankook
Keep in mind that none of these sidewall designs look like my
Goodyear Wingfoot 215/60/14 which is more bubble shaped :hurt:
~Z~
Here goes the Kelly Tiresz I was speaking of from
Les Shwabb for $85 each.
My Performance GT Gran Prix 215/60/R14 raised white letter
tires came in yesterday and they look AWESOME :D, so still making progress :):):):)
they're T rated for 118MPH
but I'ma have them sypened for more grip ^^
~Z~
