m4xwellmurd3r Posted September 19, 2007 Share #25 Posted September 19, 2007 the hoses are new, that's the thing (all fuel lines and brake lines were replaced before i got the car)so i don't really want to cut them. There is a bit of slack, so would it hurt to cut off just barely enough to slip them off, then just use the slack to put it back on? Link to comment https://www.classiczcars.com/topic/25547-how-to-replace-injectors/?page=3#findComment-222200 Share on other sites More sharing options...
zbane Posted September 19, 2007 Share #26 Posted September 19, 2007 I don't think that there would be any problem with that, though I am concerned with something you said: "they are really stretchy." FI lines are interwoven with mesh and wire. They do not stretch. At all.Do the hoses say on them "For Fuel Injected Engines"?If they don't, they have fuel line for the carbie engines. Link to comment https://www.classiczcars.com/topic/25547-how-to-replace-injectors/?page=3#findComment-222201 Share on other sites More sharing options...
m4xwellmurd3r Posted September 19, 2007 Share #27 Posted September 19, 2007 I took a look at them for ya. they're Hiprex fuel lines.they aren't really strechy, they just feel weird to me because i'm used to the normal stiff braided fuel lines of carbie cars. Link to comment https://www.classiczcars.com/topic/25547-how-to-replace-injectors/?page=3#findComment-222203 Share on other sites More sharing options...
zbane Posted September 20, 2007 Share #28 Posted September 20, 2007 I have had some luck in the past with similar problems by spraying on some PB Blaster. It won't harm the rubber, and is able to sneak between the hard and soft lines. It's worth a try, and if you haven't gotten any PB Blaster, you might as well get some-the stuff is great. Link to comment https://www.classiczcars.com/topic/25547-how-to-replace-injectors/?page=3#findComment-222225 Share on other sites More sharing options...
m4xwellmurd3r Posted September 20, 2007 Share #29 Posted September 20, 2007 Cool, thanks for the tip. I'll try it out once i get my next paycheck, that way i can get it insured, get a 30 day tag, and drop the tank out to get it flushed. Link to comment https://www.classiczcars.com/topic/25547-how-to-replace-injectors/?page=3#findComment-222226 Share on other sites More sharing options...
