That sounds a bit strange.
It has been a long time since I fiddled with Z SU/Hitachi carbs. but my SP310 Roadster has brass fittings in the fuel bowl.
Once I got them out I was able to grit blast the innards of the bowl and remove all the nasty corroded alloy and sediment.
If you do indeed have steel drain plugs, perhaps a prolonged bath of WD-40 or similar will enable you to loosen them up.
If the threads are trashed perhaps they can be bored out and re-threaded for a larger plug, BRASS this time:devious:
https://www.classiczcars.com/topic/25681-fuel-bowl/#findComment-222880
  • Who's Online   2 Members, 0 Anonymous, 1,493 Guests (See full list)
