kcoke Posted September 27, 2007 Share #1 Posted September 27, 2007 So I found a LSD 3.54 gear ratio differential. If I swap this into my 71 240z that has the stock differential which i believe the gear ratio to be 3.36 what kind of difference will I see. Is this a better upgrade? Any performance difference? Also I am running a 5 spd tranny and l24 modified. Thanks Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/ Share on other sites More sharing options...
240ZMan Posted September 27, 2007 Share #2 Posted September 27, 2007 There are 2 issues: a) the 3.54 ratio will generate more torque at the rear wheels giving a little better acceleration, but at the expense of needing to shift more often and hurting mileage a little. Do you want/need an LSD? Do you have any issues with losing traction with your inside rear wheel now? If you don't, you might not want to install the LSD. They are not completely transparent as you will probably notice it when turning sharply at slow speeds (parking lots), and also may notice it changes how the car handles at speed. You didn't say which 5 speed you're running, but you might want to spend some time at http://www.geocities.com/z_design_studio/transmission.html to see how the change will affect your speed in gears. Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-222920 Share on other sites More sharing options...
kcoke Posted September 27, 2007 Author Share #3 Posted September 27, 2007 its a 280zx 5 speed transmission and the LSD is already installed whats the pros and cons of doing this swap? Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-222931 Share on other sites More sharing options...
Nigel1943 Posted September 28, 2007 Share #4 Posted September 28, 2007 ZX is a stronger tranny than the original 240. Better still if it's a late one (ratios closer). Good swop, only down side (dependant on which tranny you had in the first place) is your 1st gear may be a bit low and you may need to change the speedo drive in the box but having said that if it all came out of the same car then this won't be a problem. Increase in gas mileage will be marginal as will top speed but having said that acceleration will be improved. Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-222977 Share on other sites More sharing options...
Marty Rogan Posted September 28, 2007 Share #5 Posted September 28, 2007 So I found a LSD 3.54 gear ratio differential. If I swap this into my 71 240z that has the stock differential which i believe the gear ratio to be 3.36 what kind of difference will I see. Is this a better upgrade? Any performance difference? Also I am running a 5 spd tranny and l24 modified. ThanksIs that a Subaru LSD ? Did you have to change the out put flanges on the sides? If so, how difficult was that? any other mods that you needed to do.Thanks,Marty Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-222990 Share on other sites More sharing options...
kcoke Posted September 28, 2007 Author Share #6 Posted September 28, 2007 I didnt do it. I saw it on ebay and wondering if I should bid on it and if its good swap? http://cgi.ebay.com/ebaymotors/datsun-nissan-510-240z-visocs-LSD-limited-slip-diff_W0QQcmdZViewItemQQcategoryZ33731QQihZ005QQitemZ150165594710QQrdZ1QQsspagenameZWDVWQQtcZphoto Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-223019 Share on other sites More sharing options...
jmortensen Posted September 28, 2007 Share #7 Posted September 28, 2007 I know you can use the Clutch LSD, but I'm not so sure about the viscous LSD. You might check with a 510 forum before you buy this thing. The 3.54 is a tall rear gear for use in conjunction with the ZX 5 speed. It will be relatively low in the rpm range at speed, so when you go up hills or when you're passing you'll have to downshift to 4th more often. A 3.90 is what came stock with the ZX 5 speed. A 4.11 would be nice. Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-223023 Share on other sites More sharing options...
red_dog007 Posted September 29, 2007 Share #8 Posted September 29, 2007 I would rather go with a 3.9 or 4.11. That is what I am keeping my eye out for. Even thinking of getting an old rusted 1980zx cause I want that 5-Speed and I wouldn't mind settling for the 3.9, but I had rather get the 4.11. 1980zx 5-Speed w/ a 3.9 or 4.11 is the route I am going myself. Best for acceleration. Just taking advantage of the cars strong points, already having awesome handling, making it pull out of corners even harder will capitalize on the strength of the car. Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-223056 Share on other sites More sharing options...
Dreco Posted October 3, 2007 Share #9 Posted October 3, 2007 i have a 3.9 LSD.. used to have a 3.54, great for highway, but horrible for track, it was too tall for my liking.. Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-223442 Share on other sites More sharing options...
Mr Camouflage Posted October 4, 2007 Share #10 Posted October 4, 2007 Thought it looked too small to be an R180. Its an R160. Link to comment https://www.classiczcars.com/topic/25686-lsd-354-gear-ratio/#findComment-223511 Share on other sites More sharing options...
