engine trouble part 2, it isn't the spark..
Hello, ok i finnally got emough time off work to check and play around, anyays, there is good spark. and it's now running on 4 cylinders, 1-2-3-4 are running now, 4 just started today got it on teh road legally now, but not dribving it till this is working, anyways coudl it be stuck valves i got some rislone in there today and let it run a bit, now i got one more cylinder working, i was told that runing the engine, while only 4 of the cylinders are running the other two, the oil in them will be washed away by the gas that isn't geting burnt up is htis true, thanks
hey guys, so today i come home, start the car up, it goes, of course, take it for a small ride, as i am just leaving the yard i give it gas, a big cloud of smoke flys out the tail pipe, and i just fly, go for a ride, wow it has ALOT more power than yesterday, park it, check to se if it running on the last three cylinders, yup it is, not GOOD running but myabe after a bit more of running it will run better. anyways thanks for your help guys
  • 3 weeks later...
ok so i have been driving it lately quite abit, however I took it for a good ride, out to the lake about an hour worth of driving there and back at abotu 95mph or so...When i get back shes running pretty smoothly, then I go for a ride and i notice that the power isnt' there, so i check the cylinders to see if they are fireing, nope so i turn the car off check the oil, IKES that is kinda low not damaging low but just a tiny bit below the low mark, i fill er up on oil... voila i got six cylinders again..you guys think that i might have soem worn out rings on this old ride?? thanks
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
