Double check to see what it would cost to put together the package together at your local auto parts store. The documentation to install and what you need is readily available on this site or a few others. (Nice thing aoubt the autoparts store is you can return things relatively easy if you pick up the wrong part).
FWIW
https://www.classiczcars.com/topic/25940-ebay-brake-kit/#findComment-225486
