http://www.autobodytoolmart.com/pc-10285-499-9605-evercoat-rage-gold-premium-lighweight-filler-112.aspx
I used this and found it to be very good, it is yellow in the can with blue hardener so when you mix it up it goes green and is really easy to see when you have the right mix.
It's really easy to sand and drys very fast, I had no problems with it clogging my sandpaper. I also bought some finishing putty but found it was harder to sand than the gold so it is still sitting in my garage.
Make sure you beat the dent out or use a slide hammer to pull it out.
  • Who's Online   1 Member, 0 Anonymous, 1,461 Guests (See full list)
