Noddle Posted November 25, 2007 Share #1 Posted November 25, 2007 http://cgi.ebay.com.au/Tripple-Webber-Inlet-Manifold-FOR-DATSUN-L24-L28-Motor_W0QQitemZ260186092400QQihZ016QQcategoryZ102336QQssPageNameZWDVWQQrdZ1QQcmdZViewItemNigel Link to comment https://www.classiczcars.com/topic/26333-tripple-webber-manifold-on-ebay/ Share on other sites More sharing options...
s13drifter Posted November 26, 2007 Share #2 Posted November 26, 2007 bit expensive or not??Looking at getting one of these middle next year does anyone make them new?? Link to comment https://www.classiczcars.com/topic/26333-tripple-webber-manifold-on-ebay/#findComment-229782 Share on other sites More sharing options...
s13drifter Posted December 26, 2007 Share #3 Posted December 26, 2007 To answer my own question:Redline PART NO. 12-3126 Tripple webber manifold $354.00 new from holley warehouse. Link to comment https://www.classiczcars.com/topic/26333-tripple-webber-manifold-on-ebay/#findComment-232070 Share on other sites More sharing options...
Noddle Posted December 27, 2007 Author Share #4 Posted December 27, 2007 Maybe this would have been a better buy ?http://cgi.ebay.com.au/DHLA40-Dellortos-for-Datsun-240Z-260Z-280ZX-240K-R30_W0QQitemZ200185465235QQihZ010QQcategoryZ102336QQssPageNameZWDVWQQrdZ1QQcmdZViewItemNigel Link to comment https://www.classiczcars.com/topic/26333-tripple-webber-manifold-on-ebay/#findComment-232153 Share on other sites More sharing options...
aarc240 Posted December 28, 2007 Share #5 Posted December 28, 2007 Just watch out for the inlet tract length.Aside from clearance of carbs to body (not usually a problem) this affects two areas you should consider.SK Sanyo is about the longest tract I've tried, gave good mid range up (3000 on) and plenty of room for decent header shape.Redline is a little shorter, power band started around 3300 with SAME carbs on SAME motor. Didn't create any header problems either.Unbranded manifold tried looked pretty similar to the one in the first link, MUCH shorter, required different headers to get clearance and the power just fell off (like died!) below 3800.This was all with same Webers, same exhaust (after the headers), rather aggressive cam, big valves and a 3mm overbored L28.A smaller engine is going to want more revs before it gets things flowing in the manifold and will exaggerate the charateristics.Hope that saves someone else the wasted time. Link to comment https://www.classiczcars.com/topic/26333-tripple-webber-manifold-on-ebay/#findComment-232201 Share on other sites More sharing options...
s13drifter Posted December 28, 2007 Share #6 Posted December 28, 2007 I have also been told that!!! I told Baz from Datsport I was going to get a redline and he said it isnt the best the Sanyo one is but its better than alot of the other repro one out there. He was of the thinking that on my l24 with a stage 2 cam, mild porting, and 10.5:1 comp it should have between a 3800-7000 rev range.Cheers. Link to comment https://www.classiczcars.com/topic/26333-tripple-webber-manifold-on-ebay/#findComment-232238 Share on other sites More sharing options...
