76Datsun280z Posted December 13, 2007 Share #1 Posted December 13, 2007 Since there has always seemed to be a lot of threads with people in need of help with their 280z EFI systems, I have come up with an idea that might get those people in need of help on the right track and give them a little basic knowledge about how the fi's on these cars work! This in return would give us a break on not having to explain everything and how the efi system work so often as they could refer back to the sticky post for those types of questions. Not only this, but they could refer back that post for example and they will know what the parts are called so there wouldn't be anymore of the "black part on the top left", but the actual name and part so we would know exactly what their talking about the first time. I'm not however implying that this post would be all the answers to all their techincal questions, that's not the point of it. The point is to give them a basic understanding of how the Bosch efi system works on these cars and what the parts are called before they ask their question. That's why the sticky post would be called "Please read before you post your efi question" at the top of the help and fi sections of the forum.Basically this might include a link to the atlantic Z car page and a link to the the efi bible. Better yet, a diagram that shows the names of all the parts on the fi system that could be posted right into the post so it's easier to refer to for part names without clicking the links. I would do this from my book, but my scannor I can't seem to get my scanner to work.Before I posted this, I pm'd Stephen (sblake01) as he is our big fi guy here on the board and he thought that is was a good idea so I forwarded the message to Mike who in return liked the idea. There are down sides to everything, and like Stephen mentioned, different model years differ and sometimes these cars get tampered with by previous owners. This is why it would be great if all you efi guys could chip in and post links, diagrams information, common problems (all efi related) or whatever you feel is necessary to be included in this post. Please keep it as simple as possible. Since a lot of us own different years of 280Z's, you might have some stuff to chip in on here as you're familiar with that particular year of car. Hopefully you see what I'm getting at. I will wait maybe a week or so and this will go you all a good chance to post what you want into the post. Once this is done, I will copy and paste everything into one post and send it to Mike who in return be the one to make the sticky post.Like I said my scanner is not working at this time to post that diagram of the efi names and pictures of each part, but will keep working on it. Here are the links to the EFI bible and the Atlantic Z car page. I will start off:Electronic Fuel pump- Pumps fuel from the tank to the engineFuel Damper- Acts as "muffler- that is, it keeps pressure surges from making noises which could be heard by the driverFuel Filter- Filters out particles in the fuel before reaching the inectorsFuel injector- Spray fuel into the combustion chamberDropping Resistor- Causes a voltage drop so that the injector operates on less battery voltage and also protects the injector from voltage surges coming from the alternator from the effects of other parts in the electrical system.Electronic Control Unit (ECU)- Controls the injectors by turning their ground on and off. Governs how much fuel is injected by holding the injectors open for longer or shorter periods of time.Fuel Pressure Regulator (FPR)- Keep the pressure in the fuel system to a constant 36 psi.Air Flow Meter (AFM)- Measures the amount of air coming into the intake mainifold. The more air passing through, the farther the flap inside will be pushed open.Idle speed screw- Use it to adjust the idle speedThrottle Position Switch(TPS)- Contains a set of contacts inside that tell the ecu if the engine is either idling or declerating. Water Temperature Sensor- Allows the ecu to richen the mixture until the engine arrives at opperating temperature.Air Temperature Sensor- Measures the temperature of the air coming in from the air cleaner.Cold Start Valve- A seventh injector to add additional fuel on a cold start up. Only gets current when the starter is cranking.Thermotime Switch- Opperates according to both temperature and time. (Hopefully somebody can come up with a better definition than that).Air regulator- Allows the engine to be at a fast idle to aid in warm up.http://www.atlanticz.ca/zclub/techtips/EFI&fuel.htmhttp://www.atlanticz.ca/zclub/techti...ectionbook.pdfhttp://www.atlanticz.ca/zclub/techti...e_Bulletin.pdfPlease chip in what you would like to see in this post! 2 Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/ Share on other sites More sharing options...
280z1975 Posted December 14, 2007 Share #2 Posted December 14, 2007 I would suggest putting a photo of each of the EFI components and then also a larger shot of the engine bay with them labeled.Since I suggested the idea I will also implement the idea to ... just won't happen till Monday or Tuesday as I have work all weekend long. On a better note, my car is now registered, licensed and insured to terrorize the Belgian roads ... that only took 6 months to complete! Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-231378 Share on other sites More sharing options...
mgood Posted December 14, 2007 Share #3 Posted December 14, 2007 Great info from you both, my car runs great now but you never know. The info is always helpful. Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-231381 Share on other sites More sharing options...
rewiredz Posted December 14, 2007 Share #4 Posted December 14, 2007 Thermotime Switch- Opperates according to both temperature and time. (Hopefully somebody can come up with a better definition than that).the thermotime switch controls the cold start valve, by changing the ground as the engine heats up. turns the cold start valve off so it doesn't have a rich mixture a long time after startup. Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-231387 Share on other sites More sharing options...
sblake01 Posted December 14, 2007 Share #5 Posted December 14, 2007 Actually, the thermotime switch has a coil that begins to heat up when it gets a signal from the starter but only when the coolant temperature is below 35 deg. C. and will only operate for a maximum of 8 seconds at which point the cold start valve will close. It really doesn't have anything to do with the mixture other than allowing the fuel to flow through the cold start valve during that duration. Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-231390 Share on other sites More sharing options...
76Datsun280z Posted December 14, 2007 Author Share #6 Posted December 14, 2007 Thanks gusy,Since I suggested the idea I will also implement the idea to ... just won't happen till Monday or Tuesday as I have work all weekend long.That would be great! Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-231402 Share on other sites More sharing options...
76Datsun280z Posted April 8, 2008 Author Share #7 Posted April 8, 2008 For any 280z owners that are in need of fuel injection help, please refer to these links and information given on this page before you make a post in the help section so you will have a better understanding of how the fuel injection system works on your car. By doing this, it will in hope give you a better understanding of what the problem is and when you do post your question, it will in return give our fuel injection guru's a better understanding of what the problem is on your car. Electronic Fuel pump- Pumps fuel from the tank to the engine Fuel Damper- Acts as "muffler- that is, it keeps pressure surges from making noises which could be heard by the driver Fuel Filter- Filters out particles in the fuel before reaching the inectors Fuel injector- Spray fuel into the combustion chamber Dropping Resistor- Causes a voltage drop so that the injector operates on less battery voltage and also protects the injector from voltage surges coming from the alternator from the effects of other parts in the electrical system. Electronic Control Unit (ECU)- Controls the injectors by turning their ground on and off. Governs how much fuel is injected by holding the injectors open for longer or shorter periods of time. Fuel Pressure Regulator (FPR)- Keep the pressure in the fuel system to a constant 36 psi. Air Flow Meter (AFM)- Measures the amount of air coming into the intake mainifold. The more air passing through, the farther the flap inside will be pushed open. Idle speed screw- Use it to adjust the idle speed Throttle Position Switch(TPS)- Contains a set of contacts inside that tell the ecu if the engine is either idling or declerating. Water Temperature Sensor- Allows the ecu to richen the mixture until the engine arrives at opperating temperature. Air Temperature Sensor- Measures the temperature of the air coming in from the air cleaner. Cold Start Valve- A seventh injector to add additional fuel on a cold start up. Only gets current when the starter is cranking. Thermotime Switch- the thermotime switch has a coil that begins to heat up when it gets a signal from the starter but only when the coolant temperature is below 35 deg. C. and will only operate for a maximum of 8 seconds at which point the cold start valve will close. It really doesn't have anything to do with the mixture other than allowing the fuel to flow through the cold start valve during that duration. Air regulator- Allows the engine to be at a fast idle to aid in warm up. http://www.atlanticz.ca/zclub/techtips/EFI&fuel.htm http://www.atlanticz.ca/zclub/techti...ectionbook.pdf http://www.atlanticz.ca/zclub/techti...e_Bulletin.pdf Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-243364 Share on other sites More sharing options...
rkramer Posted April 24, 2008 Share #8 Posted April 24, 2008 My shout is Great Idea! I'm one of those guys who will be studying it. Thx!! (71' 240w/83zxt transplant).. Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-245176 Share on other sites More sharing options...
trykflyr Posted May 17, 2008 Share #9 Posted May 17, 2008 Great idea!! First question it appears.....just bought a 76 280z. runs well for about 15 minutes and then runs rough. feels like it's running rich and flooding out. i'm leaning towards a temp switch, but it doesn't sound like the thermotime switch is the bad guy based on what i've read here. any other ideas?? Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-247738 Share on other sites More sharing options...
sblake01 Posted May 17, 2008 Share #10 Posted May 17, 2008 I'd lean towarards the water temperature sensor or it's connection. If it were the thermotime switch, it would take less that 15 minutes for the symptoms to show since that would likely lead to constant flow through the cold start valve. Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-247750 Share on other sites More sharing options...
TomoHawk Posted May 17, 2008 Share #11 Posted May 17, 2008 I just had my car on a lift to check the fuel pump strainer. I should've had my camera to get pics of the pump & damper for ya. :stupid:I'll get you pix of the other things first. Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-247760 Share on other sites More sharing options...
trykflyr Posted May 17, 2008 Share #12 Posted May 17, 2008 Thanx Stephen.... i was leaning that way as well. I hate chasing electrons.....is that switch NC or NO? If it's NO, I should be able to jump it and fool the system. Link to comment https://www.classiczcars.com/topic/26501-sticky-efi-thread-please-chip-in-fi-guys/#findComment-247784 Share on other sites More sharing options...
