whats wrong with splitfires and slick 50?
You guys always have the best comments!!!! I dont understand whats the matter with splitfires? I hear they fire better and more constistantly than NGK's. At $6.84 per pair they better do something really good!!! Hey did i tell you about the guy at the auto shop i go to, he is Chinese and he complimented me on my car. Even gave me these two really kool chinese word stickers. Said they mean "Speed Attitude" Think i'll find an appropriate place to put them on my Z and take a pic and post it. Oh one last think, anyone ever use Lucas Oil Stabilizer in there manual tranny? I just dumped a 32 oz bottle in there with 32 oz of Slick 50 80-90wt gear oil. I think i slightly over filled the capacity but should be ok.
Tony
if you know what teflon is or what it is commonly referred to as PTFE, just do a google search on the subject or that and internal combustion engine and ptfe or teflon.
it is something that you dont want in your car. unless you want to take the chance of ruining it.
me never use it never will
good oils in my book petroleom(sp?) based, castrol, mobile
synthetics only one that i use or like is mobile one
oh i almost forgot your trusting the parts guy:finger:
never ever trust the parts guy, he is there to sell you the highest priced part he can. not necessarilly the best for your car. i used to part time at a parts place. its funny how many people you see buying plugs that dont match there car.
ie Bosch in mitsubishi's or nissans, autolites in toyotas, (though i think they make a good plug), its silly. NGK's were made for your car. split fires are a joke and do nothing for your performance or gas mileage.
i had them in the Z i bought in cali, as soon as i got hom new NGK's. guess what nothing changed except it ran a little better and my mileage did not suffer.
always remember this. a spark can only travel to one point at a time. thats why i think Bosch's +4's are the biggest joke on the market. but hey thats just me. people will glady throw away 5 bucks a plug just because someone says there good.
  • 1 month later...
Basic electric lesson.It will travel the path of least resistance.Once you have built up enough carbon(insulator)on the electrodes Mr. electric will determine a single path of least resistance.The factory designed that engine and tested it using ngk.It's hard to beat those guys in the brain department.Bosch are for german cars.NGK for japanese.My old chevy is AC.
Heck all of this makes good conversation. But unless you drive hard and fast, your plugs will not make much noticible difference. Unless you never change them at all... I have noticed a difference from plug to plug, but I only noticed it when I was pushing the car hard, (which I do alot) . But most people do not drive that way. So if you like splitfires, go for it. Are they the best plug? Probably not,,, It's your car , run Champions, or anything else it your business... If you really want the best plug, I would recomend listening to what the majority of people from a racing background recomend. That is NGK. I am currently running Autolite platinums. (could not find NGK) They seem to work fine. I used to run Champions, and Bosch... They worked from fair to OK... The only way to be sure is to try the different brands and convince yourself. The wrong plug will not likely hurt your engine (as long as it is the correct size) it just may not last as long or provide maximum performance.. Have fun experiment.
  • 1 year later...
Hi all,
The issue with Slick50 and Split Fire plugs is they don't live up to their claims. When these products first came out (Slick50, sometime in the late 80's and Split Fires, early 90's.) the internet was not on the publics radar and hence it was much much harder to verify their claims. Marketing hype and testimonials were really all the consumer had unless they were willing to do alot of research on their own. Hence, these products established themselves to some degree. Of course, human nature of "wanting something for nothing" also helps propagate the myth that these products worked.
However, it's now fairly simple to dispel the hype on these products and others like them with a simple web-search. Take the time to check it out and you'll see they have no merit.
BTW, I've used both of them several times in the early 90's, (yes, I was just as much a victim of hype and human nature.) and can attest that I saw nothing that the placebo effect wouldn't account for with regards to "performance,effeciency, improved sex life, and thicker stronger hair.....
It's your money and if you want to buy these things, they probably won't hurt your car but, you'll get the same benefits to your car as if you wrote a check to "Santa Claus" and sent it to the North Pole for the same amount.
Best Regards,
Landmizzle '72 240Z
Ditto. Multi-tip plugs DO NOT create a twin or quad spark. There is still only one arc. It will travel in the direction of the least resistance--to one of the electrodes. Those ads with the furious multiple sparks are a joke. Kinda like the pest-control guy's truck with the black widow spider on the side with the red hourglass ON IT'S BACK!
Repeat after me:
NGK BPR6
NGK BR6
NGK BPR6ES
NGK BPR7
Maybe BPR8, but I doubt it
Possibly BPR5, but I doubt it.
Got to your local Car Quest or NAPA autoparts store and ask to see the NGK book nonmenclature. It is on the first page of the catalogue. It explains all the codes. If you have a seriously shaved head and/or domed pistons, you might want a 3/8 projection. Or go to sparkplugs.com.
To quote one of my favorite people on here, "Bosch plugs belong in German cars. Autolites belong in Fords. Champions belong in lawn mowers."
steve
When I was young and an easy mark for marketing campaigns, I tried all of the stuf that came out and said it was better, I don't remeber how much money I spent to find this out(but I'm sure I could have had one hell of a paintjob.): If the rest of your ignition system is up to par, L-series engines run best on clean NGK plugs.
Will
... several years ago, walking the pits by the Splitfire pits. Multiple cars, monster car hauler, big graphics, Splitfire this slitfire that, yadda yadda yadda. NGK boxes opened and empty lying everywhere. Thought that was pretty funny. We'll sped your money but we won't use your product. They should have at least hidden the boxes after they put the plugs in.
I run NGK BP6EY V Power Plugs, here's why according to NGK's website:
The V Groove "Forces the spark to the outer edge of the ground electrode, placing it closer to the air/fuel mixture. This allows the spark to more quickly ignite the mixture, providing more complete combustion....NGK's patented v-groove design allows the ignition system to easily spark in these dense air/fuel mixtures. The flame kernel will quickly grow and allow the engine to potentially make more power since it now is operating more efficiently. As an added bonus, the v-groove forcing the spark to the outer edge of the ground electrode helps reduce the "quenching" effect, reducing misfires caused by high cylinder pressures "blowing out" the spark."
When I put the L28E in my 72 I decided to try these plugs. No, you can' tell any difference really, but they are NGK so what the heck!
Chris
  • Who's Online   0 Members, 0 Anonymous, 1,038 Guests (See full list)
