From my experience, if fluid is leaking out of the reverse switch, the tranny is over-filled. Oil should be about 1/4" below the fill plug hole, which is about even with the reverse switch. I have even heard of some who fill the tranny thru the reverse switch when they can't break the plug free. In the meantime, maybe try some teflon tape (plumbers stuff) or maybe an O-ring on the switch.
It seems to be leaking through the switch itself not from the threads. The case was filled to the exact level and no more (I left the plug off until the level dropped to below the filler hole). I have about a dozen other switches but why put one in to find out it leaks too.
So what sealant stops gear oil (under a small amount of pressure)?
