I recenly purchased an l24 to put into my 72 240z, it has the stock su carbs but the mechanical fuel pump (or where it should be) has been blocked off. I imagine that is so an electric fuel pump could be run insted. My question is what the heck do I do? Do I get one and put it where the mechanical used to be and where and what do I buy? Thanks
ps when are we going to play forza 2 on xbox? my live id is xxrejoyxx, look me up !
https://www.classiczcars.com/topic/26626-which-eletric-fuel-pump/
There are a variety of fuel pumps out there that would work. Many are very noisy though. I use a early 80's carbureted RX-7 pump. Quiet and puts out a solid 4 psi. It mounts in front of the fuel tank. There is probably wiring already in place for the pump. The fuse holder is located under the center console. Search for fuel pump wiring here and over at hybridz.org for more info.
