Assuming you have located and removed the two STOP BOLTS, #18 and #19 in Fig. 9.20, you can get the piston out by using a GENTLE application of compressed air to the front port.
A bike pump will probably do it, just make sure the other end of the M/C is covered over with a rag to arrest the projectile once it starts moving.
I am rebuilding, as opposed to buying new, based mostly on how few (25,800) miles the car has on it. Sure, all new would be nice, but I don't think its always necessary, and my budget isn't unlimited ($10 for a rebuild kit/$100 for a new master cylinder). As far as going larger, I would imagine the stock 7/8" master cylinder is plenty for a 2,200 lb. car.
