Interior Repairs - Gauges & Seat Belts
Hi
Do you know someone that might fix or repair the 3 gauges located in the center of the dash.
Also would like to know how to clean or repair the original seta belts? Does anyone do it before?
Thank You and appreciated your help
Filipe Azevedo
Filipe,
What is wrong with your gauges? The clocks are known for going bad. ZClocks has a good reputation for replacing the internals of the clock with a quartz movement that will last a long time. For your other gauges, it might be a simple fix, or you might have to try to buy some used or aftermarket gauges.
For your seatbelts, I have seen posts by people that Snake-Oyl Products does a good job.
I do not know if either business does overseas shipping.
By the way, it does help to state the year and model of your car when you post.
Steve
Filipe,
If the seat belts you are talking about are original, them you may want to consider replacing them with new stock belts! Reason....these are safety items and should not be taken lightly. They likely are not as strong as when new. It's your behind however!!!
Tom
Filipe,
Tom
Tom,
Are you aware of a source for new stock belts? I haven't been searching for a while, but I never have seen a source before. The closest ones I have seen were offered at the Courtesy Nissan website, and they weren't TRULY stock as they do not retract. However, those belts are new. I know that Snake-Oyl products will replace the webbing of the belts. I do not know if they will replace the mechanical internals that can be subject to wear.
I installed some aftermarket 3-point seatbelts from WESCO in my 73. I have pictures of the installation in my gallery.
Steve
