Rear Wheel Cylinders From Other Datsuns?
Hello all!
This is my first post. I dont own a Z car but will be occasionally driving my dad`s 240Z(not sure if its a 72 or a 73) and will help with basic maintenance. So, being that i`m in the philippines its not easy to get parts(even good used ones) so we usually have to order from abroad , or, SUBSTITUTE other parts. I cant totally trust aftermarket suppliers here, so i gotta ask what other DATSUNS use the same REAR wheel cylinders as the 240Z? Oh, its a U.S. version car. Thanks in advance!
Patrick
It's even worse that you think, Patrick. Not only am I unaware of any other Datsuns that use the same wheel cylinder, but not even all 240Zs use the same cylinders. '70-72 used one type, and the '73's used a different type.
That bad huh! Thanks for the info Arne. You musta spent a good amount on your OEM wheel cylinder Gary,of course that would be the ideal way to go for a stock setup i guess. I`m on a budget though so aftermarket is fine with me. Anyway i paid for a left and right wheel cylinder branded SANYCO. It fit ok till i discovered it said 13/16 on it versus the correct larger 7/8 inch. Now i`m not a mechanic or engineer, but i do know that smaller cylinder pistons on the rear decreases the rear braking power and changes the front/rear brake BIAS. My concern is how much this can negatively affect braking CONTROL and POWER during my day to day driving(especially on curves). I dont race cars but may occasionally want to stretch the 240z`s legs once in a while. I`m especially concerned about EMERGENCY braking situations! So thats the little theory that i know. So anybody here with any experience on what actually happens in a real situation (Any other websites you might reccomend)to help me decide if i should just return these wheel cylinders and order from abroad. Thanks! Patrick(PATZ is fine too)
Okay i decided to just refund my money for the wrong 13/16 wheel cylinders and will order the correct sized 7/8 ones(aftermarket) from AUTOPARTS WAREHOUSE. They`r made by Raybestos and will cost a reasonable $56.95 each. Now my headache`s gone!
THANK YOU EVERYONE!
Patrick
  • Who's Online   1 Member, 0 Anonymous, 684 Guests (See full list)
