Firstly the car feels like its bottoming out the suspension on tiny bumps in the road. The previous owner decided to cut the springs :(
Would it be more cost effective to find used stock springs or get some sort of after market spring? The car has a 327 SBC so its a bit heavier on the front end. What would you recommend?
Secondly, at freeway speeds it has a nasty shimmy that is bad enough that I avoid the freeway. What could cause this? Bent wheel? crappy cut springs? Bad alignment?
Thirdly, Will a 16x7.5 +22, 16x8.5 +37 set of wheels fit underneath the fenders? I have ZGs that came with the car, along with holes in my rear quarters :(
Thanks for your time,
Jake
Im all ears
https://www.classiczcars.com/topic/27054-suspension-issues-on-my-new-z/
Bad tie rods (outer and/or inner), steering coupler, ball joints, steering rack, steering rack bushings, front control arm bushings could cause a shimmy.
Not without spacers. The stock offset is 0, however, the maximum backspacing you can have without rubbing the strut housing is 4 to 4.5 inches. The 16x7.5 +22 will have a backspacing of 7.5/2 + 22/25.4 = 4.6 inches; the 16x8.5 +37 is even worse with a backspacing of 8.5/2 + 37/25.4 = 5.7 inches.
  • Who's Online   1 Member, 0 Anonymous, 526 Guests (See full list)
