June 1973 240z - E12-80 distributor - car died, won't start
Hi all
I have a June 1973 240Z with an F54 L28 & Mikuni 44 PHH carbs.
It's had an E12-80 electronic distributor & MSD Blaster2 coil for 4~5 years now & has always run like a champ.
On Friday evening it randomly died on me at a stop light in town.
Wouldn't start up again. I pushed it to the side.
Made sure it had fuel + spark + E12-80 wiring was nice and tight.
After an hour of fidgeting she fired up again but with some hesitation at low revs. I managed to struggle home and parked it out in front.
I just spent all afternoon on it and it still won't start!
_I had new-ish NGK BP6ES R plugs - but pulled those out and swapped in brand new ones gapped to 0.85mm
_New NGK blue plug wires - I tested resistance and found that they are all about 6500~7000ohm when attached to cap (factory wear limit is 30000ohm)
_Cap & Rotor are basically new, but I still swapped both out to rule that out
_I tried two different E12-80 distributors (mine and one that's been sitting on workbench in garage).
_Distributor neither fully retarded nor fully advanced - set right down the middle.
_I tried two different coils (my Blaster 2 coil & stock new 280zx coil)
_I made sure the wiring was as it has been for the past years.
_I pulled the wires off of the + & - of coil and made sure there was no corrosion on the blades - steel wool until they were shiny
FYI My E12-80 module wiring has never looked like this:
http://zhome.com/ZCMnL/tech/ZXPertronix.htm
_Tank has fuel & starter does crank & crank & crank but engine just won't start however.
I've always attributed that to my car being a 73 and having the later tach which receives a signal from the - post, not the + post like the 70-72 cars do.
Can someone with a 73 & an E12-80 spell out if they are using the above diagram or something else ?
Again I've had it running like this for years w/o a hitch...
What the heck?
I feel like I've tried everything...
Help?
Thanks.
-e
They symptoms say "bad module" is the first place to look ... they usually go out when they overheat - letting the car sit and cool allowed it to start one last time... using the original set up - ice down the module and see if the car will at least start....
I don't like swapping in used parts that I don't know for sure are good.... did you have the second distributor running in another car recently (yes/no?)
Did you say that you checked and you have power to the coil with the ignition key set to run? and did you check power at the coil when the ignition key is switched to 'Start"?... maybe your ignition switch is the problem...
Just thinking... off the top of my head...
FWIW,
Carl B.
Carl
Thanks for the reply.
how do I check if the E12-80 module is indeed bad?
the spare distributor I had on the shelf I actually don;t remember if i ever tested it before or if it has ever been on the car before...
I guess it's possible both distributors have bad modules - wouldn;t that be my luck? :)
i did not take voltmeter to coil - but I can certainly try that and report back
-e
ok
So I've now tried 3 distributors, 2 coils, new cap+rotor+plugs, checked plug wires & I get no spark
Has to be wiring right?
Forget the tach what's the minimum I need to get the car started?
GW & BW which used to go to ballast resistor get spliced together, E12-80 B lug goes to + post on coil, and?...
Thanks
Am at work right now, not in front of car, but I can report that:
Battery voltage is probably starting to get low since I've been trying to crank it for a day or so...
Starter still SOUNDS healthy - not wheezy just yet...
(good ol' optima)
-e
I take back what I said
No spark at sparkplug
0.5 volt at + coil when key is in ON & START positions
Just picked up another spare E12-80 at junkyard
Going home to try it out
You SoCal guys kill me! You can stop at lunch at a salvage yard and get Datsun parts! I have to call all surrounding salvage yards and ask if they know what a Datsun is, and if I'm lucky, they have one or two!
Hope you get it nailed down and back on the road!
You have to figure out why you do not have power at the + terminal of the coil and E12-80 module. Get power there and she will run.
Hi all
What the heck?
Help?
Thanks.
-e
Classic failure of a 12 80 Module. Loose the Blaster coil , and go with a OEM coil and all will be good. Just went through this with a friend and after frying 3 modules found the Blaster is the cause. Puts out the wrong values for this ignition. Thank you Kim Blough for the heads up. Gary
