But I'm looking to see if anyone has pictures of the lift points for a '73 S30 (assuming its different from year to year), as well as the points to place the jack stands.
I have a bunch of stuff that I need to get done on my new Z (oil change, find a leak, fix a dented rim :cry:) but I don't know where to lift from. Thanks for the help :D
https://www.classiczcars.com/topic/27124-not-sure-where-this-goes/
Take the middle of the front axle and than put the stands right and left to this.
At the rear lift at the end of the diff. Be careful, put wood or - better - thick rubber between the diff and the lifter. Work careful and look that the lift is vertical, than put the stand under the rear lifting points as descipt in your manual (use rubber between lift and lifting point). That's how I work when in a hurry.
  • Who's Online   2 Members, 0 Anonymous, 1,371 Guests (See full list)
