Posted February 20, 200817 yr comment_237901 Today I bought a '84 Maxima Alternator. Does anyone know what the output is for one of these. I did a search but only found several threads on how to do the upgrade. I know how I just want to know the Amp output . Gary Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/ Share on other sites More sharing options...
February 20, 200817 yr comment_237918 60 amps. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-237918 Share on other sites More sharing options...
February 20, 200817 yr comment_237978 My Maxima alternator tested at 105 amps when I bought it. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-237978 Share on other sites More sharing options...
February 21, 200817 yr comment_238066 Nissan equipped the Maxima’s with a variety of different amperage alternators depending on year and exact application (different electrical loads). A summarized chart would be:60A 1981-198470A 1985-198680A 198590A 1986-199495A 1992-1994 100A 1995-2003110A 1995-2003120A 2004-2006125A 1995-2003Notice the overlap. In addition, repair houses will attempt to cover several years/models with one replacement alternator, so you never know what you will find in the junkyard. In general I have found that the earlier 70A and 90A Maxima alternators are easier to swap into a S30 than the later ones. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-238066 Share on other sites More sharing options...
February 21, 200817 yr comment_238078 The 78-80 810 also used the internally regulated LR160-42 alternator that Steve listed for the 81-84 Maxima. That's the same one used in the 78 280Z and similar enought to be interchangable with the 280ZX LR160-82B alternator. The the turbo ZX used the 70 amp LR170-02B and I'm still looking for a couple of those for my cars. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-238078 Share on other sites More sharing options...
February 21, 200817 yr comment_238081 The 70 amp ZXT units appear to be hard to find. Even parts suppliers generally sell the 60 amp unit as covering all ZXs, both turbo and NA. So if a ZXT in a boneyard ever had its alternator replaced, it likely has the 60 amp unit instead. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-238081 Share on other sites More sharing options...
February 21, 200817 yr comment_238084 I look for the numbers on it if they still exist. And I have a buddy with a shop that can test the output. I like that 'part supply' line in your sig. I would really have to stop and think about how many Datsuns out there have parts in them that I was somehow involved in over the years. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-238084 Share on other sites More sharing options...
April 25, 200817 yr comment_245310 I'm considering swapping out the alternator in my '72 with a self regulating, 90 amp unit from a 1996 300ZXT. Will I have any problem with this swap as far as wiring sizes go? I don't really have any "electrical add-ons" beyond stock components.THANX for any advice you can offer this Z-neophyte.Kamikazi72 Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-245310 Share on other sites More sharing options...
April 25, 200817 yr comment_245331 Without electric windows, computers and fancy HVAC systems, how much power does an early Z need? I think you can add a decent stereo without upgrading the alternator. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-245331 Share on other sites More sharing options...
April 25, 200817 yr comment_245332 I have the ever-popular 60 amp ZX alternator on my '71. I noticed that if I sit waiting for a green light with the lights on, turn signal going, wipers and heater fan running, none of these things slow down or dim while the engine is idling. With the original 40 amp alternator, things got ugly in that situation. So I'd say that my experience is that more than 60 amps is not necessary unless you have a lot of extra consumers. Link to comment https://www.classiczcars.com/forums/topic/27132-maxima-alternator-up-grade-in-a-240z/#findComment-245332 Share on other sites More sharing options...
