Dashboard Restoration - Material?
I am looking at Dashboard Restorations, USA, to restore my trashed dash. They are out of the traditional "haircell" type of covering material and are sending me a sample of an alternative material, which I should get shortly. Any thoughts on type of cover I should use or not use? Anyone out there who has had their dashes recovered lately have any ideas or thoughts? If the haircell material is the desired cover, I can source that from another company, if need be.
I appreciate any input!
Thanks!
https://www.classiczcars.com/topic/27197-dashboard-restoration-material/
The only input I can offer is I assume its going to cost alot to do this, and for that price I would want to make sure it looked original. I might walk away if all I could get was an alternative covering. Maybe can you buy a crack free dash used for the same money?
  • 2 years later...
I had my dash done by Dashboard Restorations and was extremely pleased with the results. The dash is in my garage--awaiting my 240 which is still at the body shop. I will post pictures once I install it.
Be careful with the so called 'uncracked dashes' that occassionally show up online. Make sure you can inspect it first--to see if the material still has some 'give'. You don't want it to crack as you're installing it in your car!
Edited by Rich1
I was pretty impressed by some of the results posted in this thread:
http://www.classiczcars.com/forums/showthread.php?t=23919
I'll probably go that route when the time comes. For now, I'm just afraid to look under the half cap a PO installed...
duffman,
Hair cell is the closest texture to original, in my opinion, but it is not an exact match. I had my dashes done by DR years ago and was quite satisfied. I looked at a lot of textures and none were an exact match. I don't think there is an exact match. So don't worry about it.
I did this to my dash as a temporary fix, I does look good. But I am seeing new cracks forming and the repairs do not look like they will last long. If you want you're car to look nice on a budget go with the full dash cap, If you whant it to be a show car send it in for repair and pay a $hit load of ca$h. My 2 cents (its all I have).
  • Who's Online   2 Members, 0 Anonymous, 1,404 Guests (See full list)
