austex Posted March 11, 2008 Share #1 Posted March 11, 2008 Hey guys, just looking for the horn relay. I'm assuming I know the general location, so which one of these is it? The previous owner did some intersting wiring, so I'm in for some fun in the near future... Same location, just a different angle. Link to comment https://www.classiczcars.com/topic/27332-horn-relay-location-74-260z/ Share on other sites More sharing options...
SteveJ Posted March 11, 2008 Share #2 Posted March 11, 2008 Well, if the wiring diagram in the Clymer manual is correct, the horn relay has a green wire with black stripe, a green wire, and a green wire with a white stripe. However, it doesn't help narrow down the location. Link to comment https://www.classiczcars.com/topic/27332-horn-relay-location-74-260z/#findComment-240269 Share on other sites More sharing options...
EScanlon Posted March 11, 2008 Share #3 Posted March 11, 2008 See if one of those has the letters "H - B - S" stamped in relief on the top (letters may not be in the exact sequence). That's what the earlier relays had.2¢E Link to comment https://www.classiczcars.com/topic/27332-horn-relay-location-74-260z/#findComment-240273 Share on other sites More sharing options...
austex Posted March 12, 2008 Author Share #4 Posted March 12, 2008 Haha, I managed to detach the panel with the relays on it, after much pain. Sure enough, H-B-S. It was the one at the very top, and the relay below it was covering up the screw holding in the horn relay. Good grief...Thanks for the help!Josh Link to comment https://www.classiczcars.com/topic/27332-horn-relay-location-74-260z/#findComment-240290 Share on other sites More sharing options...
