I would use a spring from a Z. It will have the proper size and tension for the weight of the door. You should be able to find one at a junkyard or maybe someone here that is stripping a car out for parts. Been a lot of them losing their life lately due to too much rust seems like. :cry:
Never had to do it, but I would say you could probably do it without removing the whole door. You could try to block the rear of the door to hold it up(maybe with a jackstand) and just remove the hinge itself. There should be someone here with a complete door hinge from a parts car, you could try placing a wanted ad in the classifieds here.
  • Who's Online   1 Member, 0 Anonymous, 273 Guests (See full list)
