Don't forget that it's a 3-part set. While you can make some things work, others require more work and effort than it's worth.
You don't mention if you did replace all of them or just the dash one. If you replaced the set then just find a tach that works with the loom. If on the other hand just the one, then replace it.
E
  • Who's Online   2 Members, 0 Anonymous, 1,257 Guests (See full list)
