I guess the better question is what are you trying to do to make your car handle better. Most guys say I need bigger swaybars, but actually there are other items you can modify that will make your car handle better depending on the handling issues you are dealing with.
Big swaybars on your early Z car will rip the framerails apart...
https://www.classiczcars.com/topic/27671-sway-bars/#findComment-243531
What do you consider large?
Fixitman
https://www.classiczcars.com/topic/27671-sway-bars/#findComment-243600
Anything larger than 3/4" on the front, is large.
Let's rephrase the question, why do you think you need big swaybars on your car?
I am rethinking the size of the bars on my early '74 260Z. It currently has 1 1/8" dia. front and 7/8" dia. rear bars. These were the sizes offered by Quickor in the early '80's for this model and year. I believe Suspension Techniques offers the same size bars today. Are these too large for a street car?
Thanks,
Fixitman
https://www.classiczcars.com/topic/27671-sway-bars/#findComment-243781
Before I installed my ST bars, I reinforced the frame rails where the bars connect using 1/8" steel plate shaped in a U-section. The stiffeners slipped over the frame rail and where welded into plate. I then drilled through the frame rail and had them install 1/8" steel tubing between the top and bottom plates. I then ran longer bolts when mounting my front bar and attachd it from the top.
https://www.classiczcars.com/topic/27671-sway-bars/#findComment-243830
  • Who's Online   3 Members, 0 Anonymous, 1,141 Guests (See full list)
