Grab it like a thumb tack and gently pull straight up. If it's anything like the 240Z tach.
I had to pull mine to put on the MSA white face gauge kit, that I might add "Sucks". The 240Z tach needle rests at zero so it makes it real esy to set the needle back to zero when re-installing.
You'll notice on the below pics that the screws lifted the sticker a little. I think this can be fixed by using a very thin washer for the screw head to turn on, rather than binding on the vinyl.
They sucked because the vinyl kept peeling up when the gauge got warm. I completely washed and used an alcohol swab on every inch of the faces, and they still peeled.
The tach alignment is off,
They don't make a Speedo gauge for the early 240Z's, like mine, I had to make my own.
Just not happy with the whole $70 purchace and end up having to redo half of them and also make my own.
7277, I look at them everyday, hard to NOT notice every detail
  • Who's Online   2 Members, 0 Anonymous, 1,287 Guests (See full list)
