Lightft01 Posted May 7, 2008 Author Share #13 Posted May 7, 2008 Alright, just wanted to say thanks for all your help, Never got the fuel pump working off of the stock harness, but ended up pulling the pump, and noticed that the strainer in the inlet line for the pump was filled up with gunk. cleaned that out and replaced the fuel feed line from the tank to the pump, and got fuel back to the rail. The next day the pump went out so i replaced it. Now the car runs, but misfires like crazy, and runs really rich (blowing black smoke), the car sounds like it has a huge cam in it. Pulled the spark plugs and they are all fouled, but the #'s 1,2,5,6 cylinders were really bad. Going to try swapping injectors, and see if that helps, is the fuel pressure regulator a common problem with these FI systems?? Link to comment https://www.classiczcars.com/topic/27847-1978-280z-fi-relay/?page=2#findComment-246587 Share on other sites More sharing options...
ALConfederate Posted May 8, 2008 Share #14 Posted May 8, 2008 From what I've been told you need 36 PSI. No less and no more -- if you have more you run across problems like you're describing. Have you done a fuel pressure test to see what that pump's putting out? Link to comment https://www.classiczcars.com/topic/27847-1978-280z-fi-relay/?page=2#findComment-246604 Share on other sites More sharing options...
sblake01 Posted May 8, 2008 Share #15 Posted May 8, 2008 Actually, the test doesn't determine what the pump puts out. It determines whether or not the system discharge pressure is being properly regulated. Link to comment https://www.classiczcars.com/topic/27847-1978-280z-fi-relay/?page=2#findComment-246650 Share on other sites More sharing options...
HKSZ Posted May 8, 2008 Share #16 Posted May 8, 2008 If it runs that rich from the get go I'd be checking the thermotime switch and cold start valve, sounds like they're wired to stay on Link to comment https://www.classiczcars.com/topic/27847-1978-280z-fi-relay/?page=2#findComment-246656 Share on other sites More sharing options...
