Can the stock 240Z alternators be boosted to put out more amps?
I like to keep it simple, plug and play.
I am looking to upgraded.
Below is a link to an aftermarket one but it's $900.00us.
Has anyone used them.
http://www.powermaxx.com/main.htm
Below is a list of electrical stuff it would need to handle:
Fuel Injection Engine and all its goodies
100 watt headlights
100 watt driving lights
(HID is still to costly)
Rear Fog light
Air Conditioner
Stereo System
Alarm System
Laptop Computer
Cellular Phone
Radar Detector
Refrigerator -- ice chest type
https://www.classiczcars.com/topic/2792-aftermarket-alternators/
Currently, the lights run dim at idle at 800rpms. At 1000, the lights are fine. I have HELLA E-spec H4 w/55-65 watt bulbs.
If I change the pulley size, smaller, then I should have enough juice to power everything at idle.
Who makes aftermarket pulley wheels?
Has anyone tried that?
The upgrading to a higher amp alternator may not be necessary.
Chevy alternators need only 1 wire to hookup into your electrical system & have an internal voltage regulator. One of the engine swap guys could tell you how to hook it up. They come in different Amp sizes, but you'd need one that will fit physically, too. The only tough part would be to ge t the right mounting bracket.
