Weasel73240Z Posted May 1, 2008 Share #1 Posted May 1, 2008 So I bolted up the new ZTherapy SU's, and barely got her to start. Very weak, no throttle response. As careful as I was, I'm thinking the most likely thing is that I'm 180 off with my distributor. Any other ideas? Link to comment https://www.classiczcars.com/topic/27938-ne-sus-not-running/ Share on other sites More sharing options...
Mike Posted May 1, 2008 Share #2 Posted May 1, 2008 Paul, I moved this into the SU Central forums. If you're having troubles with the carbs after purchasing from ZTherapy, I suggest that you call their main number (on the website: http://www.ztherapy.com). They also frequently read this area of the forum and might be able to chime in with help. But, your best bet is to call. Link to comment https://www.classiczcars.com/topic/27938-ne-sus-not-running/#findComment-245859 Share on other sites More sharing options...
