This is stage one
The car has been into a “pyrolyse” oven!
That’s an oven whit only dry heat no flames. Slowly they turn on the temperature up to 360 degrees Celsius and that is 680 Fahrenheit and even so slowly they let it come down.
Otherwise you it could happen your car transformed in something you do not like.
Its not a well know procedure but surly effective. Al the paint, underneath car protection **** and old rubbers are gone with the wind.
This means you have to do the whole car as if it where new from the assembly line. New kit layers new paint underneath, inside and outside. And also the insides off the frame.
A hell off a job and I won not recommend it anymore.
https://www.classiczcars.com/topic/2795-from-hell/
  • Who's Online   0 Members, 0 Anonymous, 1,436 Guests (See full list)
