xray Posted May 3, 2008 Share #13 Posted May 3, 2008 If you're using a 3-ohm coil from Pertronix, the BR is not required. If you're using the 1.5ohm coil, the BR is required. If the BR is not used, the 1.5 ohm coil may over heat and/or damage the Pertronix unit.However, having run both setups, I can say that the 1.5ohm coil with stock BR runs better than the 3-ohm.Stock BRs can be found at MSA, on Ebay or (I think) at nissanparts.cc Link to comment https://www.classiczcars.com/topic/27953-please-help-me/?page=2#findComment-246054 Share on other sites More sharing options...
GILDIA Posted May 3, 2008 Author Share #14 Posted May 3, 2008 I check for the connection and the cable are connected the Gw an BW I run it with and without this connection but i don't get any spark, Link to comment https://www.classiczcars.com/topic/27953-please-help-me/?page=2#findComment-246118 Share on other sites More sharing options...
Friar-Tuck Posted May 3, 2008 Share #15 Posted May 3, 2008 Do you Have GOOD Clean ground ? It took two weeks for me to find Poor ground. :stupid: Engine block -- Body-- Alternator--even ran ground to intake manifold and small ground wire from block to distributor base at timing adjust tab bolt. (Easy to test with alligator clip test leads) Tuck \o/ Link to comment https://www.classiczcars.com/topic/27953-please-help-me/?page=2#findComment-246122 Share on other sites More sharing options...
sblake01 Posted May 3, 2008 Share #16 Posted May 3, 2008 I don't know about all of that. My cars run fine without running extra ground wires. If you have to do that, then something else is wrong. Link to comment https://www.classiczcars.com/topic/27953-please-help-me/?page=2#findComment-246136 Share on other sites More sharing options...
GILDIA Posted May 5, 2008 Author Share #17 Posted May 5, 2008 Tank you all, i am goinig to check for the grounds, Link to comment https://www.classiczcars.com/topic/27953-please-help-me/?page=2#findComment-246330 Share on other sites More sharing options...
