Installing the GEN II Mini A/C into my 240
On 7/7/2018 at 9:25 PM, Dude said:
Derek  can you please tell me what type of metal used to melt the AC unit under the dash and if you could tell me where you purchased them ?
the mounting might be a little different from when Derek installed his, I've noticed some of the older guides have a different designed gen2 mini. I'm currently in the works of installing a newly bought gen2 mini in my 260z, I made a bracket yesterday, I still need to test the fit of it, and finish an upper bracket. I welded some 1" bars that are ~1/4" thick, I had to modify the top bracket to fit correctly, but can't run grinders this late, have to be courteous to the neighbors ha.
Heyitsrama well you will have to let me know how they turn out[emoji3] also I’m sure if the neighbors knew what you were doing they would appreciate it[emoji1360][emoji28]
There are 3 mounting points, with 4 pieces.
Here they are painted after a test fit
Them placed into the car, I’m running a 260Z the front mount might be a little different from pictures I’ve seen. I have to test and see if the dash fits, it should, just have to double check [emoji85]
