I'd like to replace the stock muffler with a over/under twin tip similar to the old Ansa design. Does anyone carry such a thing anymore ? If so, who ? If not, what other popular options are there ? I'd like a more aggressive sound and a better looking tip than the stock setup.
I'd also need to know what diameter the pipe leading into the stock muffler is so I can ensure I have the correct slip on tip.
Thanks for any help!
https://www.classiczcars.com/topic/28015-exhaust-tip/
Hi again,
Thanks for the help guys,
I'll check out the Monza and Pacesetter exhaust systems and see if anything looks good. I do like the classic over/under Ansa tip look, you'd think there would be knock offs of those readily available, but most anything I've found has the tip angle cut so the pipes would need to be side by side and not over/under. Anyhoo, I'll keep looking and let ya'll know what I settle on.
78Datsun280Z, yup we're crusin' the same streets. I'll keep and eye open for ya !
https://www.classiczcars.com/topic/28015-exhaust-tip/#findComment-246590
Well, I found what I wanted on the Black Dragon site, it part number 89-300
http://www.blackdragonauto.com/icatalog/z/full.asp?page=67
Really all I want is the tip and Pace Setter won't sell it seperately, but they did say that it's part number 812222. The whole system is $300 including shipping, and that seems extreme when all I need is the tip. I've scoured the net and I can't seem to find anyone that even sells the complete 240Z kit other than BD.
Anyone have any ideas where I can buy just the tip ?
https://www.classiczcars.com/topic/28015-exhaust-tip/#findComment-246658
I don't believe Pace Setter/Monza sells that tip by itself anymore. If they ever did. I doesn't show on their site.
That's what I discovered this morning. They'ed sell more if they did, but hey, it's their business.
I ordered the whole thing and plan to just put the pipe away for now.
Thanks all.
https://www.classiczcars.com/topic/28015-exhaust-tip/#findComment-246684
I got the Black Dragon 89-300 Monza pipe and stuck the tip on today. It sounds good and throaty. The pipe they send is larger diameter than the stock one, so I had to wrap the stock pipe a bit to get the tip to fit. I'll put the new pipe on later when I can take it to a shop.
https://www.classiczcars.com/topic/28015-exhaust-tip/#findComment-247730
