guy_geo Posted May 10, 2008 Share #1 Posted May 10, 2008 Here's the problem..1. At a stop, when the car is either cold/warm, pushing the brale pedal produce a hissing noise inside the cabin.2. Pedal is really firm, like no assist is available..3. When the brake pedal is pressed at a stop, the car shudders and want to die...4. No leak, brake fluid is ok, have been changed last year...What would be the problem??Thanks,Guy Link to comment https://www.classiczcars.com/topic/28052-brake-booster-idle-problem/ Share on other sites More sharing options...
sblake01 Posted May 10, 2008 Share #2 Posted May 10, 2008 Possibilities:Hoses/check valve:1. Bad hose between intake manifold and check valve2. Bad hose between check valve and booster 3. Leaking check valveBooster itself:4. Dislodged reaction disc5. Leaking push rod seal6. Leaking between valve body and seal7. Leaking valve plunger seat8. Bad diaphagm1-4 can be repaired/replaced the rest would require a new booster. Link to comment https://www.classiczcars.com/topic/28052-brake-booster-idle-problem/#findComment-246804 Share on other sites More sharing options...
guy_geo Posted May 10, 2008 Author Share #3 Posted May 10, 2008 Was checked this morning.. brake booster busted..Will need a new one.. Link to comment https://www.classiczcars.com/topic/28052-brake-booster-idle-problem/#findComment-246894 Share on other sites More sharing options...
