Caen Fred Posted May 11, 2008 Share #1 Posted May 11, 2008 Is the 240Z starter from my 240Z auto man enough to crank the L28 with a 1mm slimmed head? In fact it's not even turning the engine at all at the moment! The starter is fine and was OK on my 240Z engine...???? I took it off and it run OK I can turn the engine with 30 lb/ft on my spanner???? When I turn the key, I hear the cliks... it turn 1/4 max and nothing more???? Could it be the battery? I am not speaking about starting the enging... just turning it at the moment Help, I need to prep my car for Le Mans Classic Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/ Share on other sites More sharing options...
sblake01 Posted May 11, 2008 Share #2 Posted May 11, 2008 A lot of people like to use the late 280z or 280ZX starter since it's a gear reduction starter. I've always had those starters in both of my cars (the Z and the 810). Both basically stock so I don't have anything to compare it to. Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-246960 Share on other sites More sharing options...
Caen Fred Posted May 11, 2008 Author Share #3 Posted May 11, 2008 My concern is that it doesn't move the "=§*** thing at all????? Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-246962 Share on other sites More sharing options...
sblake01 Posted May 11, 2008 Share #4 Posted May 11, 2008 The starter I mentioned is 'supposed' to have more torque. Like I said, I don't have anything to compare it to. Hopefully someone else will answer. Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-246965 Share on other sites More sharing options...
Force Fed Posted May 11, 2008 Share #5 Posted May 11, 2008 Why don't you try another battery? Or put some jumper cables to it? Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-246969 Share on other sites More sharing options...
ALConfederate Posted May 11, 2008 Share #6 Posted May 11, 2008 So is the starter trying to rotate at all after the initial quarter-turn or does it just crap out at that point? Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-246974 Share on other sites More sharing options...
e_racer1999 Posted May 11, 2008 Share #7 Posted May 11, 2008 ya, sounds like either a corroded/loose cable or a dead/dying battery to me... double check all of the cables; heck, disconnect all of them and give them a good scrub with some sandpaper. make sure your ground is solid and touching bare metal. it sounds like the starter isn't getting enough juice Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-246976 Share on other sites More sharing options...
ALConfederate Posted May 12, 2008 Share #8 Posted May 12, 2008 No, I'll tell you what I'm thinking -- I'm thinking a starter gear and a flywheel that, for whatever reason, aren't meshing right. The Bendix turns just a little and then everything binds.Of course, I'll be the first to admit I don't know if that's even a possibility here. But I don't want to discount it, either. Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-247023 Share on other sites More sharing options...
Carl Beck Posted May 12, 2008 Share #9 Posted May 12, 2008 Is the 240Z starter from my 240Z auto man enough to crank the L28 with a 1mm slimmed head? A starter for a 240-Z will crank your L28 with no problem. Stock 240-Z starter will crank my L24 with 13:1 compression, and my L28 with 10:1 compression.If yours will not - you have some other problem.FWIW,Carl B. Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-247030 Share on other sites More sharing options...
Caen Fred Posted May 12, 2008 Author Share #10 Posted May 12, 2008 Ok Carl, you have a 240Z starter on a high comp engine and it turns okay so I will double check the connections and try with a biefier battery then...What size should I aim for... Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-247095 Share on other sites More sharing options...
Arne Posted May 12, 2008 Share #11 Posted May 12, 2008 Here's a thought - the 240Z came with different starters (and solenoids) for manual and automatic transmissions. I've always assumed that the difference was in the throw of the bendix drive. The later cars used the same starter regardless of transmission. So if you have swapped from automatic to manual transmission on your car, you may need a different starter. Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-247096 Share on other sites More sharing options...
sblake01 Posted May 12, 2008 Share #12 Posted May 12, 2008 From 78-83 (84 if you include the Maxima) they used a gear reduction starter. It is a better starter but that's not to say that the earlier one is a bad starter. If I had an earlier S30, and I had to buy a new starter anyway, I'd go with the later one. Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/#findComment-247097 Share on other sites More sharing options...
