Caen Fred Posted May 16, 2008 Author Share #13 Posted May 16, 2008 Ok, I had a good deal on an Oprima red top... cranking OK now... so much juice I could do a 15 mile trip on one crank :cross-eye Now I have yet to start it... that's an other story Thanks all Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/?page=2#findComment-247659 Share on other sites More sharing options...
Carl Beck Posted May 16, 2008 Share #14 Posted May 16, 2008 You'll find that the Optima red top will also hold a full charge far longer than the lead/acid batteries. I agree with the others that recommend the later gear reduction starters, if you have to buy a new starter anyway. I used the 240-Z starter on the BRE Z, only because that is what was on it as raced in 73. Nonetheless, it worked out fine...FWIW,Carl B. Link to comment https://www.classiczcars.com/topic/28066-240z-starter-on-l28/?page=2#findComment-247686 Share on other sites More sharing options...
