I have noticed that the door gap on S30 cars isn't exactly even, or the same all the way around. The front & rear gaps are, or can be, the same ( about 3mm) but the gap at the top-front corner ( where the mirror is) seems to be noticeably bigger.
Is that correct? I have had a few musclecar guys tell me I need to adjust the door gaps, but after I told them what I have is normal, I get some crazy looks, and show judges (at non-z car shows) say the same, and since you can't tell the judges what's what, so I get hammered point-wise.
I can get a picture.
thxZ
https://www.classiczcars.com/topic/28190-uneven-door-gaps/
TomoHawk,
That area is a normal "slack" area-most Zs I have seen have that issue until an owner takes issue with it and corrects it.
Before your next re-paint sand the surface clean and fit and weld a section of metal coathanger to the door-make the gap uniform by grinding the coathanger, sand it flush to the surface of the door, and add a touch of filler if needed, then continue with the repaint, and your gap is uniform...no more lost points, and no more Muscle head issues!
Will
https://www.classiczcars.com/topic/28190-uneven-door-gaps/#findComment-248322
Thanks.
Those muscle-brain guys are peculiar, anyway. How would they know what's right on my car? One guy told me my carburetor was missing! (It's sopposed to be on top, between those two cylinder heads, and half your spark plug wires are missing...)
I don't know if he noticed that my hood opened up on the wrong end.
:(:ermm:
thxZ
https://www.classiczcars.com/topic/28190-uneven-door-gaps/#findComment-248496
Stephen, you slay me! That may have been my Dad!
He was at a gas station when he noticed a lady fueling up her brand new small convertible and said, "Nice car! is that a new Miata?"
The lady scoffed, and got in her brand new Z-3 and drove off.
Bwahah ahahah ahha
https://www.classiczcars.com/topic/28190-uneven-door-gaps/#findComment-248506
Hey don't sweat it, American muscle cars are great don't get me wrong, but they all suffer from that same 60's-70's build quality that all manufatures had. The $100K + restorations is mainly in the labor to make the doors line up correctly! I've seem many a restored muscle car and everyone complain about how the body fits together and how much time they have in fitting it properly.
https://www.classiczcars.com/topic/28190-uneven-door-gaps/#findComment-249921
